The easy availability of applications—games, consumer-oriented utilities and third party tools—for mobile devices results in end users installing and running unauthorized personal programs and recreational software on devices meant for business use. In addition to contributing to memory and battery life overhead, this situation also contributes to productivity losses. The installation of unauthorized and unapproved non-business applications contributes to a significantly higher volume of support calls, increasing the IT help desk's support burden. Most critically, it is imperative for security-conscious users to control and restrict the unauthorized installation of personal applications to ensure compliance with strict mobile data protection requirements. MobiControl's application run control features reduce the risk of leakage of sensitive data and complement the existing network security model by preventing the introduction of malware and viruses into the network through the mobile devices. Additionally, it also allows memory management on the mobile devices to free up resources taken up by unnecessary processes, and allowing for better device performance. MobiControl integrates tightly with the operating system to prevent restricted applications from running entirely on the mobile device, making it much more efficient than competing white list and black list solutions which use CPU and battery-consuming processes to monitor for and destroy restricted applications. To enable application run control for a device or group of devices, select Application Run Control Policy from the MobiControl Security Center. (Please see the iOS Device Security page.) Application Run Control System Configuration![]() Application Run Control dialog box System Tab The following table will describe the features provided on the System Tab.
Application Run Control Blacklist Applications![]() Application Run Control dialog box Blacklist Tab Control List CreationConfiguration of application run control begins
with the creation of an application control list. An application control list is simply a listing of the names of the
Bundle Identifiers that correlate to the application you may wish to disallow on the mobile device. For example,
Manual ModeManual list creation is provided for the device administrator who already knows exactly which Bundle Identifiers are to be put on the black list. This advanced feature is only recommended if you are aware of the names of the Bundle Identifiers that need to be allowed for correct device operation, and those that you wish to restrict. You can manually create a new application control list by clicking the New button in the Application Run Control dialog box, and then choosing the Manually Create a New Control List option in the Select Control List Creation Method dialog box. The New Application Control List dialog pops up, allowing you to specify the application that you want to add to the list, and the platform for which this entry would be valid. This allows you to restrict applications on a device running a specific operating system (e.g. Windows Mobile 5), if you have a mix of devices with different operating systems in the same group. Once created, the list may be applied to one or more devices or groups. ![]() Creating a black list in manual mode
If you edit an application control list that is shared among device groups that are not subgroups of the group you are configuring, the changes will not be propagated to the other devices. The modified control list will only affect devices belonging to the group being configured or its subgroups. Modifying or Deleting a Control ListAn application control list can be edited whether it is currently in use or not, but its type (white list or black list) cannot be changed once created. An application control list can only be deleted if it is currently not selected for any devices or device groups. A control list that is listed in the Selected field is considered in-use, even if the application run control is disabled for the given group or device. Application Run Control Event NotificationEvery time MobiControl's application run control feature detects an application that is not allowed to run by the security policy in effect, it will notify the server. The Notify Server on Application Termination option will generate a log event on the server and display it in the Event Logs for that particular device when an attempt is made to run a blocked operation. Device logs can be viewed in the MobiControl Manager by highlighting the device or the group of devices and enabling the Logs tab. This allows the administrators using MobiControl Manager to track any attempts by the end users to run or install unauthorized applications and ensures a higher level of monitoring. |
